Hello all
I have looked through the site and cant find the answer. So I hope you can help.
I am trying to come up with a solution to operate a door. the door is massive (weighs around 500kg) and slides open and closed. With the use of rollers and bearings it can be pulled closed with about 20kg of force. I have found the solution to move the door in the form of an actuator (from SKF.com)
My problem comes in controlling it.
Also being installed on site is a new access control system (Paxton) one part Paxton make is a io Board.
The io board has 4 inputs (12V) and 4 outputs (up to 230V 13A)
I need to bridge the two components.......
My thoughts are as follows:
A button is pressed (io input)
io board outputs through output 1
To a motor controller (to control the actuator)
Actuator closes (opening the door)
oposite to close
well that's as far as I've gotten actually........
Can I control the motion controller (Have not found one yet) with an on/off input? (relays)
So the OPEN button is pressed closing the circuit triggering an output on the io board that will send a signal to the motor controller that in turn will send a signal to the motor (attached to the actuator)
Apologies, I know this is missing a lot of info and if you need any more please let me know. Got many different tasks going on and I'm all over the place. Any help will be greatly appreciated.
oposite to close
