John said:
I need to power three Cree XLamp XRE LEDs. The standard sealed lead
acid battery is 12 V, but it is heavier than I would like to carry. I
have some spare rechargeable 14.4 V DeWalt tool batteries.
The L7812 regulator says it needs at least 14.5 V. will a 14.4 V
NiCad tool battery be acceptable for that?
Thanks.
LEDs are best driven by a constant current supply, like the
one drawn below.
+14.4 ---in|LM317|out---+
adj [R]
+---------+---[LED]-[LED]-[LED]---+
Gnd --------------------------------------------+
Choose R for the current you want by R = 1.25/I
According to the LED data sheet, the maximum current is 1 amp,
so R must be no less that 1.25 ohms. The resistor would dissipate
1.25 watts at that value, so 2 watts or higher should be used.
The LM317 will dissipate ~3.3 watts nominal at that current, but
over 6 watts if the battery is at full charge voltage (over 17
volts) and taken immediately off the charger and connected to
the circuit. So, size the heat sink accordingly.
You could use a 7812 in the same configuration with R = 12/I,
but the resistor would need to be about 10 times the wattage
of the resistor used with the LM317.
I would recommend running the thing at well under maximum current
for longer run time, less heat, and longer LED life. If you use
3.5 ohms for R, I will be ~357 mA, R will need to dissipate about
1/2 watt, and the LM317 dissipation will be under 3 watts worst
case, and about 1.6 watts nominal. You'd get more than triple
the run time that way, too.
Ed
