Dylan Wisdom
- Apr 10, 2014
- 26
- Joined
- Apr 10, 2014
- Messages
- 26
What does a common base circuit do?
Both common emitter and common base configurations have voltage gain.Bob, is right partly, if you want to amplify the voltage you will need to use common emitter
Wrong again. Common base configuration is also non-inverting.in case you do not care about 180 shift which is present at your output signal, if you want to have no phase shift for your signal then you will need common collector circuit.
Also wrong. BJTs are current-driven, but they also provide voltage gain. Input signal voltage is converted into a signal current by series resistance and/or the transistor's own incremental resistance. FETs are voltage-controlled but they can also provide current gain. It depends on the configuration.All this circuit act as current amplifiers. If you want amplify voltage then you are off looking at FET tranbsistors.
But: in a typical amplifier application you do not use this equation to design the amplifier. Typically you're looking for a linear relation between Input and Output of an amplifier, not an exponential one. Therefore you use a base resistor and/or feedback to essentially convert the Input voltage to a proportional base current which is amplified and converted back to an Output voltage by a resistor.In fact, the BJT is a voltage-controlled device (Ic=Io*exp(Vbe/Vt).
It's clearer to describe it as inversion. The signal comes out upside down. For many waveforms, such as a sinewave, a square wave with 50% duty cycle, etc, this corresponds to a 180 degree phase shift, but it's clearer to define inversion as inversion, not phase shift.This thread is an interesting read. When you guys talk about "inverting", do you mean simply that the phase is shifted?
Inversion refers to the output voltage vs. input voltage. For a common emitter stage, when the base is driven higher, the collector voltage becomes lower; that's what inversion means.I.e. If I had a square wave with a 30% duty cycle driving the base of a BJT (assuming the proper resistor is connected), does that mean that my load would experience a 70% on/off duty cycle during operation, or would it experience a 30% duty cycle with the phase shifted relative to the signal driving the base?
.......and BJTs are characterised as current amplifiers, because that's the simpler and clearer way to explain them. As Harald says, it depends on how you want to look at it, and which way is the most useful for explaining a particular aspect of their behaviour.
Nevertheless, there are some applications which - for my opinion - cannot be explained based on current-control, for example: Current mirrors and Barry Gilbert´s translinear loops.
Furthermore, I am not sure if it is possible to derive the gain expressions for the classical differential amplifier (long-tailed pair) based on the current-control model only.
More than that, for my opinion there is even a kind of contradiction when we say:
* We need a certain voltage Vbe (0.6...0.7)V to "open" the transistor, which means to allow a certain quiescent current Ic;
* However, the variation of this current (which allows output voltage variation across the collector resistor) is caused by Ib variation rather than by a corresponding change of Vbe.
