Hello guys,
I've just built this LED blinking circuit and it works wonderfully. What I'm looking to do is instead of connecting an LED I instead have the output hooked up to a relay coil. The problem comes because this circuit outputs a blinking 9v signal and the relay coil requires 12v. I'm hoping that there is some way to hook up a transistor to the blinking circuit running on 9v to then switch on and off the relay circuit running off 12 volts, with two seperate power supplies. Would this be possible?
