H
Hodgey
Hi everyone,
I've got a burglar alarm that works off a 12V transformer. The only
trouble is when the alarm is activated via the system it doesn't stop
until the system code is entered into the keypad.
I'm wanting a circuit I can cut into the 12V siren feed (from the alarm
unit) that will shut the alarm off after 20 minutes but will re-set
when the voltage feed from the system is finally lost. It has been
along time since I looked at electronic circuits so any advice would be
greatly appreciated.
I have worked with 555 timers before. Could a monostable 555 timer be
used for this application?
I'm looking for a not too overly complex solution that I can easily put
together myself using breadboard.
Thank you for your time.
Regards,
Mark Hodgkinson
Regards,
Mark Hodgkinson
