dusseldorf101
- Dec 21, 2011
- 4
- Joined
- Dec 21, 2011
- Messages
- 4
So I was hoping to create a usb phone charger powered by a TEG (Thermo Electric Generator). I haven't designed any circuits since Uni so I am really struggling putting this together and also I think it needs a variable resistor microcontroller to manage the output power/voltage.
So into the details I was looking at using a TEG like this: ThermoEelctricGenerator
The output values at specific temperatures are:
Parametric model: Temperature(℃)/Open-circuit voltage(V)/Current(MA): 20c/0.97V/225mA
40c/1.8V/368mA
60c/2.4V/469mA
80c/3.6V/559mA
100c/4.8V/669mA
The TEG would be operating between 60c and 100c so V(min)=2.4v and V(max)=4.8V and I(min)=469mA and I(max)=669mA.
This is where I need my maths checking so:
First half of problem: Proof of Concept
An iphone chargers output is:
iPhone Charger 5 volts 1.0 amps 5 Watts
So P(max)= 3.21W P(min)= 1.13W
So first of all I think I would actually need two TEG's in series so that the minimum Voltage output meets the required minimum for an iPhone Charger so for two TEG's in series:
V(min)=4.8V
I(min)=469mA (please can you confirm that current is the same in series? ~it's been a while :S)
P(min)= 2.25W
V(max)=9.6V
I(max)=669mA
P(max)=6.42W
Firstly, in principle will this work? I know that the current is alot less than the wall charger but am I also right in saying that this would just charge the phone slower?
Do I need to keep looking for a better power source? Do you know of any better performing TEG's?
Second half: Circuit Design
Because the Voltage and Current are so variable based on the input temperature I need something that is going to smooth out the voltage, what is the best way to do this? Would I be best to use a Voltage regulator or a micro controller to manage the outputs?
Any and all help would be MASSIVELY appreciated, I'm a Product Designer by trade and only have a working knowledge of Electronics and 0% knowledge of circuit design of this type.
Thanks Everyone!!
40c/1.8V/368mA
60c/2.4V/469mA
80c/3.6V/559mA
100c/4.8V/669mA
V(min)=4.8V
P(min)= 2.25W
V(max)=9.6V
I(max)=669mA
P(max)=6.42W
Thanks Everyone!!
