The Latest Build
SparkyCal
Mar 11, 2020
849
Mar 11, 2020
849
So, here is why latest build. I used Saran Wrap to wrap the circuit so that it does not touch the sides ofd the steel box. During this playing, I switched the pickup switch on my guitar three times. The first pass is the two pick ups combined, the second pass is the bridge pickup , and the last pass is the neck pick up.
The pedal itself is very flexible in that it can achieve a very hard edge distortion, or a more subdued distortion. I chose a bit of the middle ground for this video, but it can be set to sound a lot dirtier or cleaner.
In terms of the guitar amp, I am using. Roland Cube with only some reverb dialled in- otherwise it is set to totally clean. Any distortion is from the pedal. I also used an entry level Fender Squire. I like to use cheaper guitars to test these things, because if they sound good on a cheaper guitar, they will sound great when I use my tele, Strat to les Paul.
Thanks to everyone who helped me along the way- especially AG, Betrus and Harald who were helping me ever since I started. Martin, Bluejets and VenomB- I haven't forgotten you either.
I will continue on this site with more exploits. I think being able to build something successfully (finally), has motivated me to stay put here. Plus, it's a great community!
Here is the clip:
https://drive.google.com/file/d/1bxu0BWSGStn1oxPQjs95YOrrRPZWRH5r/view?usp=sharing
Technical note: I am using AG's suggestions inside the box- like his voltage divider circuit and his inclusion of a 270R resistor, a 3.3uF cap and a 10nF cap. (these are all changes from the original schematic). I am also using a socket and a 4558D chip- which, although is an older chip, sounds just fine to me.
A note on sockets. I have purchased sockets on Amazon. the first bunch worked, but they seemed rather cheap. The second bunch I ordered took a long time to get here (China), but were worth the wait. Very good quality and what I really like about them, is beside each pin (from the top view), there is a little brass circle that lets you dip your multi meter probe in to test the pin. A little added feature that is cool.
VenomBallistics
Aug 30, 2018
285
Aug 30, 2018
285
I used have a cat that'd lay atop my bargain basement 1X12 solid state combo amp for the warmth ... and rip the knobs off then look at me like "what". Since then, I transitioned to tube fired amps and use circuits like these for not much more than a means to push the amp harder with a clean boost. I get a thicker, more punishing tone while retaining the amps nearly clairvoyant response.
It's a worthy goal for the soldering musician, but you need to be dead sure of what you're doing before you tackle a full house tube head build.
I did see an interesting circuit in that archive someone else shared a while ago ... it was a 12V in, tube fired distortion with a voltage multiplier in its power supply section. It's tone control section left something to be desired, but if it behaves anything like the Behringer VT 999, it'll be a springboard to what may end up being your new favorite pedal.
SparkyCal
Mar 11, 2020
849
Mar 11, 2020
849
Do you have a schematic?
bertus
Nov 8, 2019
3,336
Nov 8, 2019
3,336
The one with a voltage multiplier is this one:
Bertus
VenomBallistics
Aug 30, 2018
285
Aug 30, 2018
285
@VenomBallistics , this is the other with a multiplier circuit:
Bertus
There she be.
Strikingly similar to the tube mic pre by the same company.
I suspect it will make a good overdrive / boost as drawn. It should also serve as a springboard for other designs since it is a two channel design, using two tubes.
These could be used in series with a marshall or fender style tone stack and other elements.
Perhaps a PT 2399 based delay or chorus.
Or at least a send return loop
SparkyCal
Mar 11, 2020
849
Mar 11, 2020
849
Wow. I think that is beyond my ability at the mom en t. Maybe as I get better at this stuff . Thank-you
VenomBallistics
Aug 30, 2018
285
Aug 30, 2018
285
Now thats no way to get in over your head.
If you read between the lines of my thoughts on the tube head schematic a few posts back, you'll see me use terms like "springboard".
This is possible because I broke these things down into tangible, bite sized pieces I can work with.
You can, and should do the same. You'll be kit bashing, modding, and designing in no time.
SparkyCal
Mar 11, 2020
849
Mar 11, 2020
849
We’ll see. I don’t give up easy and I also don’t feed ca food to a Lion. Lol. Thanks for the vote of confidence. I agree that when you breaks things down, it gets understandable
