Harold said:
snip-----
Bert,
Could you explain (in terms I might understand) why a vacuum makes a
difference?
TIA
Harold
Hi Harold,
X-rays occur when charged particles (such as electrons) are accelerated
to high velocities by means of a high voltage electric field and then
rapidly decelerated by colliding with matter.
In air at STP, free electrons tend to frequently collide with air
molecules or combine with neutral oxygen or water vapor molecules to
form negative ions (called electron capture). The average lifetime of
free electrons in air at STP is only about 11 billionths of a second.
Because of collisions and electron capture, free electrons in air cannot
reach velocities sufficient to generate potentially dangerous X-rays,
even in the presence of very high voltages and high electrical fields.
In a vacuum, free electrons can be accelerated by the applied HV field
without colliding with many gas molecules. They can be accelerated to
much higher velocities before eventually colliding with an electrode or
the walls of the container holding the vacuum. Higher electron
velocities translate into higher energy X-rays. Voltages of 10-20 kV and
above can generate "soft" X-rays, and higher voltages will generate
"harder" (more penetrating and more dangerous) X-rays.
Bert
We specialize in UNIQUE items! Coins shrunk by huge
magnetic fields, our "Captured Lightning" Lichtenberg
Figure sculptures, and Out-of-Print technical Books.
Visit Stoneridge Engineering:
http://www.teslamania.com
