Hi All,
I'm really just after some ideas on where to start.
What I want to be able to do is control the flow rate of water (cold) through a condenser system of between 0.2L p/min up to about 1.5l p/min to maintain a steady temperature of the condenser unit.
For example if the temperature starts to rise in the unit the flow rate will increase gradually to bring the temperature back into a 2deg C range of say 78-80. If the flow rate is too high and the temp drops below 78 it reduces the flow rate to bring it back into range. It’s not critical if it goes +/- 5deg C as long as it returns to the 78-80 range within say 10 seconds. I am currently doing this by hand and its pretty tedious as the process can take many hours to complete.
As mentioned not after the solution just some pointers I was thinking RasPi or Arduino to control the valves and communicate with the electronic thermometer.
Yes I’m making essential oils
What do you think?
Damien
What do you think?
Damien
