AARRRGGGHHHH ! As you can see the supply is giving me heart burn. For the second time after replacement R926, C925, Q9070, U930, Q930 gets blown out. The supply never did get repaired. The crow bar worked fine indicating the voltage at TP 940 was too high. It should be about +43 volts. It seems for some reason the voltage acroos C925 a 100 mfd 25 vdc cap blows the cap shorting R926 then taking out most of the pre-regulator parts. Any one have some ideas?
From my calculation the voltage at the base of Q928 should rise to 6.9 volts to turn Q928 on.
The voltage at the top end of R926 is 175 vdc charges up C925 through R926 a 150K resistor.
Seems to me the voltage drop across R926 is 132 vdc. C925 is only a 25 volt cap. Something crazy here. When the cap blows it takes R926 with it. Yey theirs no short to TP150 or to chassis ground.
The serial number is high starting with a B70--- Option 0
25 years ago I repaired a number of these scopes with wierd power supply issues, but this one is the worse. Another strange thing with this scope (milltary version) is the markings on the board for Q928 is marked Q944. In the correct Q944 position it's not marked at all. Traced out every line to verify this. However on the circuit board layout page of the manual it's shown correctly. Scope appears to have been extensibly worked on before. Got this one at an auction.
