John Larkin
Certain DC/DC designs lend themselves to be used with external clocks,
but the issue in not limited to switching supplies. Power supplies are
never perfect zero-ohm sources, so their will be noise on them just
from the circuit operation. Say the circuit works on band splitting
audio, as in the simpler modem designs. Then the transmit channel
circuitry will be generating noise right where the receive filter is
trying to elliminate it. If the PSSR of the receive filter in the
region of the transmit spectrum is poor, you may have a situation where
the PSSR related noise is worse than what gets past the filter.
I've seen SCF designs with gain from the power suppies if measured at
center frequency of a high Q resonator.
I did a dual-conversion superhet FSK modem full of cmos logic, a uP,
and a mess of MF10's, the original old nasty metal-gate version. The
first board worked, but s/n was awful on some channels, as the sc
filters aliased anything they could find back into my signal range. In
a double superhet, there were lots of opportunitities. With some added
rc's in the power lines, it worked fine, although the s/n still wasn't
anything to brag about.
John
