Switch mode supplies
Discussion in 'Hobby Electronics' started by atec77, Aug 9, 2010.
  1. atec77
    atec77 Guest
    I have the need for a high current 50Vdc supply (20amp), to maximise rx
    when the power is not needed will the supply handle being switched off
    and on regularily when being used ?
    Anyone have a clean schematic and any salient words as the cost of a
    good transformer is quite prohibitive so a switch mode might be a solution
    Tnx in advance
  2. ian field
    ian field Guest
    AFAIK telecoms gear mostly uses 48V, so you might be able to get a ready
    made PSU off the shelf and tweak it up a couple of volts - or better yet,
    cheap surplus gear.
  3. atec77
    atec77 Guest
    Exactly what I need but where . very little on ebay , I could run two
    units at 1kw each I guess
    Of course if I had a suitable tranny making one might be an option but
    switch mode has appeal
