Ok bit of a strange one here, and bear with me because Im a little bit of a noob with electronics.
Basically I have a couple of lasertag guns, they have 3 what I believe are IR sensors on them to detect the hits, what Im trying to do is extend the sensors away from the gun.
the sensors themselves are black 2 pin IR receivers (I think)
Anyway I removed the sensors off the pcb no problem, then I attached a 12inch wire to each point where it was joined with the sensor then attached on the ends of these wires.
Tested it out and it received hits on the sensor perfectly, however the gun wouldn't fire properly, it was sometimes not firing at all, then sometimes it was taking a few seconds for it to fire after pulling the trigger. This is where it gets strange to me...
Removed the sensor and left the wires the same length but with no sensor or anything on the ends, same problem. However if I cut one of the wires down to about an inch, or remove it altogether the gun works fine!?!? What is this voodoo? why would it matter how long the wire is especially as there is nothing even on the other ends of the wires?
The only thing I can think is perhaps the wires are acting as some sort of aerial, or causing some sort of RF interference? in which case would using shielded wire help?
thanks
Steve
thanks
Steve
