Y
[email protected]
Hi Guys,
Recently I constructed a circuit using a voltage comparator, relay,
transistor, some diodes and resistors. The output of this circuit is a
LED. By having a specific range of input, the voltage comparator will
enable the LED to be lit. LED is lit thru' the energizing of the
relay. Theorectically, all calculations made are correct and the
circuit is properly soldered. However, the LED will not light up
unless I TOUCH certain parts of the circuit (with my fingers or any
metallic objects). What can probably cause such an occurance?
ywz
ywz
