B
B. Woods
I'm completely frstrated with an SSR design I'm working on. I'm hoping
someone can tell me what I'm missing.
Facts:
I'm working with a Potter & Brumfield SSR-240D50.
I'm trying to switch a simple resistive heating coil that comes out at a
little over 4 amps at 124V.
Initially I had this hooked to a pin on my printer port. I have other, much
smaller, SSR's that I run this way. For some of my tests I put a 9volt
battery across the drive lines.
Wiring:
I have, quite literally, an electrical cord that I spliced the SSR into.
One side of the cut is on pin 1, the other side is on pin 2 (which are
labeled 120/240vac).
Observations:
Whenever the cord is plugged in I read 124v at the plugged. There isn't
enough current to drive anything, but there is energy. This concerns me.
Tests/Result:
LPT: First test was totally dead.
LPT: Second test I plugged in a light bulb, worked perfect for many
cycles.
LPT: OK, I hooked up my heating coil... dead.
9V Batt.: Back to the light bulb... works (here I'm pretty frustrated)
LPT: Hook it back up to my heating coil... Works!!!
LPT: Do some tuning on my code that drives the device, run it again...
Works intermittently, once turned off it wouldn't always come back on.
Dismantle, hook drive lines directly to 9 volts... Dead
Never works again.
(Step 10 - Hit the newsgroups at www.deja.com, find little of value, deicde
to post)
Can anyone see what I'm missing? I have similar designs running on 3amp SSR.
Is it possible that I have a bad SSR.
Here is the spec sheet for the SSR:
http://www.steveneng.com/Tech_Support/PDFs/37SOLID.PDF
<Please respond to the newsgroup> bwoods114<at>charter(dot)<net>
Brad
Facts:
Wiring:
Observations:
Tests/Result:
cycles.
Never works again.
to post)
Brad
