I haven't looked at them, but if they're lower then they're probably
even more worthless. In my experience, the EPA numbers for nearly every
vehicle claim that the MPG with an automatic transmission is better than
with a manual transmission, however on every vehicle I've owned I've had
a manual transmission and consistently achieved a better MPG than the
EPA estimates for an automatic. My current vehicle doesn't have an EPA
estimate, so I don't have a comparison there.
Modern autos lockup early and shift at the most optimum time. Some
even limit the injectors between shifts to maintain the smoothest
power delivery. Haven't you ever driven with somebody in traffic who
stays in the wrong gear? I'm assuming that the newest EPA standards
take all that and more into account. There are bound to anomalies, but
none of those will change the apples-to-apples value of the ratings.
Not all vehicles report data on fuel consumption, my '97 K3500 doesn't
for example.
Compatibility list here
http://scangauge.com/support/CompatibleVehicles.shtml. Only a few
exclusions. Unless yours is a diesel, it appears that a Scangauge
would work normally.
The best way to track mileage is to get a receipt every
time you get gas, write the current odometer mileage on the receipt and
collect them so they can be entered into a spreadsheet to compute MPG.
Few are going to go to that much trouble. Besides, the method wouldn't
be very accurate for anyone who occasionally adds fuel from a gas can
as I do. I really like having the ability to see current trip mileage,
as opposed to just tank mileage or lifetime mileage. Makes it easy to
know when and why consumption changed. I also like that the next time
somebody is telling me about their veeeeery hard-to-believe mileage,
we're going for a drive with the Scangauge hooked to their vehicle.
It would be interesting if you saved those receipts and compared those
results with what the scan gadget tells you.
Even easier - when you fill up, but before you reset the instrument,
it displays what it thinks you need to add. If that number isn't
dead-on, then it can be adjusted in seconds to add a fudge factor. On
mine it was 2%.
The best thing you can do for MPG, as well as overall safety, is to
learn to look ahead and anticipate. Coasting down as you approach the
red light vs. flooring it up to it and then slamming on the brakes as an
example. The so called jack rabbit start isn't really as big a deal as
many tout, since to get to cruising speed takes X amount of energy
whether you apply it slowly or quickly.
Well, is it your opinion that it's not "really" as big a deal, or no
difference all? What percentage of jack-rabbit types nail the speed
they're aiming for without overshooting? How many jack rabbit starts
result in unnecessary braking? How many result in staying longer in a
lower gear?
Wayne
