Sony Profeel KX2501
JURB6006
Hi;
I happen to own this one. I forgot all about it until I read the XBR Post.
Mine needs an HSTAT as well, but it's not disconnectable from the flyback. This
thing has a fantastic tube in it and I do have the matching tuner and even a
stereo decoder for it (MLV1100).
I've tried splicing in one for a normal 26" Sony and I didn't want to glue
everything until I knew it worked. Good and bad, the control was out of range,
but I got a nasty shock in the process. The HSTAT was used but it was pulled
from a set with a known other trouble. Does anyone know if this was possibly
just a bad pull, or can someone tell me if they are indeed incompatible, like
if the HSTAT drop is different on the Profeel CRT.
If anyone has my part, or if I CAN use an available HSTAT, I'd like to get it
running. If I can't do that I'd like to make the other parts available (very
reasonable, or free for minor items), and probably sell the tuner(s).
Your thoughts would be appreciated.
Thanks for your time.
JURB
