From memory: only take it ½ way to the bank.
This unit has the convergence up front right ? If so read on. The only
resistors it usually burns up are lil fuzibles or the yoke return resistors.
The lil fuzible resistors aren't real critical, basically anything that goes
off at the same current will do, but if they are yoke return resistors they are
critical. They set the gain of the output stages and as such, if you change
their value(s) you must do an unnessecary realignment on the convergenge.
Look at the PCB, do they go between the Cyoke return and ground ? If so they
are yoke returns and thus I would rather use used parts from a scrap board than
a generic replacement. They must be non-inductive. Not sure if they're metal
film or what, but they are not $0.13 resistors. They need to be accurate to the
original value.
The fuzibles really don't matter, it'll blow the 3.15 amp fuses before it cooks
the SMPS, but it might cook a convergence yoke.
There are six channels of output on that board, you just duplicate the values
from another channel.
JURB
