im looking for some cap's for my
2 power conditioners model
SOLA series 200 and 210.
the cap's are 16uf 660volt AC
large mettel can type like in
microwave ovens.
thanks
anyone
Hi
I also have a Sola Series 200 power conditioner, I recovered from a
skip outside a printing factory down the road.
It appears to basically function ie power goes in, power comes out -
whether it is in any way 'conditioned' I don't know.
I was hoping to use it in conjunction with a small GMC alternator I
picked up from Bunnings for $98. This unit is rated at 750W and runs
very nicely. The only problem is that under light loads (under about
150W), the output voltage heads for around 260 - 270 volts.
Unfortunately the output from the Sola tends to follow the input
voltage, so I am not sure if this is a fault or whether the unit is
simply not designed to regulate voltage. All that is in the unit is a
large capacitor and a very large transformer.
If anyone has any details and / or a diagram of the unit, I will be
very grateful for a copy.
TIA
Dave Goldfinch
