Small project help
Gary2880
Aug 16, 2016
Aug 16, 2016
Hello!
I was wondering if you could help me with a small project. What I'd like to do is have a LED turn on by a toggle switch. But the toggle switch would be around 20ft away from the LED. Self contained running off of a battery.
Using something like these 2 things. Afraid I've got no electronics experience or know how but I can solder if that helps.
Doesn't have to be the toggle switch if it'd cause more fuss than it's worth, just some sort of switch that would activate the LED.
Thanks for your time and any help.
Regards
Gary.
Sunnysky
Jul 15, 2016
541
Jul 15, 2016
541
You need to find out the specs on LED voltage to choose battery.
Sunnysky
Jul 15, 2016
541
Jul 15, 2016
541
Specifications:
Voltage: 4.8~6v
Looks like they are all in parallel with a small resistor added.
This range is a not a great choice for batteries. Can you locate a large enough battery for your needs in this range? Something like a lantern battery 6V then Red to V+ and black to V- and switch in series in between.
