KilgoreCemetery
- Apr 12, 2017
- 258
- Joined
- Apr 12, 2017
- Messages
- 258
I'm trying fix a Singing Machine SML385BTBK. The female power port on the back was pushed in and broken off and I was wondering if anybody knew how to identify it and where I can find a replacement one?
Measuring the female side is a bit tricky, but the male end of the AC power adapter (Model GKYPS0150058UL1) measures:
4mm OD
1.85mm ID
10mm from base to tip
Output: 5.8VDC 1500mA
Yellow tip
Is there a name or an IEC/ANSI specification for plugs like this? Does anyone know where I can find a replacement one?
4mm OD
1.85mm ID
Yellow tip
