simple relay 120v
ep4433
Mar 2, 2012
Mar 2, 2012
what is a good simple 120v relay that is on with current but off without and needs manual
reset. Is there a plug model around that I can just plug in both ends?? ...it is for when power goes out... I want it to disconnect and not reconnect unless manual reconnect.
I guess some surge supp. have relays similar in them but they are notoriously un reliable.
I need to protect some radio stuff...
i need to know where I can get one and cheap..
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
What is it that you're actually trying to do?
Harald Kapp
13,747
13,747
You can use any DPST relay with suitable contact rating in this circuit:
attachment.php
The push button triggers the relay which in turn holds itself using one of the contacts to bypass the pushbutton.
If 12 V fails, the relay will turn off, staying off until the push button is manually re-triggered.
Harald
duke37
Jan 9, 2011
5,364
Jan 9, 2011
5,364
Motor contactors are made in this way and have a green button to start and a red button to stop.
Some electrical machines have this system fitted so they do not start on their own if power is re-connected.
A search in your country should provide sources.
