S
Steve S
I'm trying to decide the best approach for a new design (consumer audio
product). For a similar product in the past, I used two PCBs:
1) Main PCB, mounted horizontal in the unit, containing 90% of the
circuitry, double-sided with components mainly surface mount on one side. It
also includes right-angle coax sockets and a DC socket that go through and
attach to the rear aluminium panel.
2) Front Panel PCB, mounted vertical in the unit, attached behind the front
panel using glued standoffs glued. It contained 3 x 6x6mm tactile buttons
and 4 x 0.7" seven-seg LED displays. This is a double-sided PCB, with all
components through-hole. FWIW the front panel is quite small - 1" high, by
5" wide.
I want to simplify and reduce the manufacturing costs for a new design of
product similar to this (quantities of 2-5k per year). So I'm considering
using just one PCB, attaching right-angle 7-seg LED displays and tactile
buttons to it for use as the front panel.
As I see it, the pro's of this approach would be:
a) Only one PCB
b) Less components - ribbon cable and header
c) No need to mount to front panel
The con's would be:
a) Harder to source right-angle displays and switches, and more expensive
b) Excess force on a connector on the rear panel would push front panel
switches and displays forward into the front panel
The rear connectors are screwed to the rear panel by one screw each, but I
think that last point may still be a concern - coax connections can be very
tight and attract a lot of user force sometimes.
Does anyone have any thoughts as to the best approach in order to minimize
manufacturing costs without causing problems down the line?
Steve
5" wide.
a) Only one PCB
The con's would be:
Steve
