B
BW
Hi!
I have a very simple op-amp circuit built around the MAX4475 single op-
amp. It is a non-inverting amplifier with gain 2x (using a resistor-
divider 5k6 + 5k6), and dumping to a 1 uF cap on the output. On the
(positive) input is a single DC voltage from a bandgap-based D/A-
converter.
Now, the strangest thing: when measuring on the op-amp output, I get a
near perfect sawtooth-shaped oscillation of perhaps 10-20 mV,
frequency maybe 30 kHz (which is not visible on the input). Varying
the resistors and/or output cap, shifts the oscillation in size and
frequency.
I'm no op-amp guru, does this sound like a pole in the transfer-
function ? Shouldn't that give a nice sine-wave ? Why the perfect saw-
tooth? Adding a forward compensation capacitor of 12 pF (as per the
datasheet suggestion exactly) doesn't change anything at all.
Basically I'm asking if anyone know if this failure-mode is a typical
decompensated op-amp buffer or if it sounds strange and could signify
some major magic ?
Initially I had the op-amp configured to drive the gate of an external
FET, with the same results strangely enough.
Removing the output 1 uF cap increases the oscillation. Changing the
output cap to 47 uF reduces the oscillation. I hesitate to do this
permanently - I want to understand why it oscillates in that way in
the first place...
Next test is to replace the op-amp with some other brand and see if
the same problem persists, of course.
Best regards,
Bjorn
converter.
frequency.
some major magic ?
the first place...
Best regards,
Bjorn
