I'm pretty sure the replacements were original Sanyo. They looked
identical to the originals in the set, with the date code above the
STK number, and some alphanumeric numbers on the aluminum in the back.
I think the cheap Chinese parts look slightly different.
All the low value resistors check out good too. I'll have to check the
supply voltages when the set is fired up. I don't have the print for
this set, but I would presume the positive and negative rails are the
same voltage.
I'll try to check for DC offset on the inputs. I wouldn't think there
would be any, but I'm only guessing.
On this Mistsubishi both modules are held in place with a single screw
in the center and a piece of spring steel. Maybe I can drill holes and
use more screws.
Thanks for the help.
LB
