When you place the parts in the same way as the other filters, it would be as easy as making a copy.
The only difference will be component values.
The coloured wires should look the same for every filter.
yeah thats whats puzzling its identical to the other 3 same with the bar graph drivers may get time on the project later and see if I can see something I missed yesterday
HOORAH
so I missed a joint on the envelope detector of the 4h filter, soldered the power for the LM3914 bar graph driver into the wrong place and hardest to find was acctually a cold solder joint on the 2.2k resistor 1/4 done, 3/4 left!!! but as promised here are a couple pics:
so I'm going to expand to the left and right and above the LED display on more protoboard the same size as the two I've used and I've added in another TL074 for the REF GND's for the remaining filters and LM3914 bar graph driver circuits! thanks
UPDATE fully made the 5th filter and envelope detector going to solder up the bar graph LED driver for the 5th column as soon as I get a chance! thanks
