Paul Lockwood
- Dec 1, 2014
- 10
- Joined
- Dec 1, 2014
- Messages
- 10
While going through all my old kit hidden in the loft I came across a 220V to 12V 3.5 Amp AC transformer.
I would like to have a go at converting the output AC to DC as per one of the YouTube videos I've recently seen.
However I would ideally like to have the transformer in a safe location when doing this and only having access to the 12v wires. If I end up using this in a permanent project then it would also need to be secured.
The transformer is one of those that are held inside a plastic mould that has two flaps either side with screw holes to fit it to something. The connections are fairly exposed with the two input and two output right next to each other.
Is there a project box or something similar that would cater for this?
A question that may cover all this is how do you secure your components / PCBs in a case so that they don't move around when picked up?
Paul
Paul
