C
Clive Mitchell
Are there any known pitfalls of running a parallel circuit of several
standard compact fluorescent lamps from one of those cheap 12V to mains
voltage convertors sold for use of small appliances in cars and motor
homes?
I'm guessing the biggest risk of damage comes from either the peak
voltage charging the internal electrolytics in the lamps to a higher
than normal voltage, or even the strange load of rectifiers and
electrolytics causing the converters problems.
I've got a tricky situation where a moving set piece which was
originally going to be powered from the mains is now to be self
contained. The last thing I want is to blow a dozen compact
fluorescents at the flick of a switch.
homes?
