g said:
Hi all
and thanks for the help in the past
Does any know how, or if you can cut and splice the antenna from a
GPS?
THe GPS antenna on my boat is shot and needs to be replaced.
THe issue is I cannot tale the radar arch apart to run the new wire
without cutting it.
So...
Any tricks of the trade to cutting a GPS antenna cable?
Check to see if it is a powered antenna, if it is there is a voltage on
the coax. You can usually check with a voltmeter at the connector. You
want to make sure the power is off before you mess with it.
Some options:
Cut the end fitting off the new coax and pull the new coax through the
arch with the old coax? Use BNC male and female connectors to rejoin
coax. There will be a very small loss in signal for adding the extra
connector but it will not be enough to worry about
if the connectors are crimped on right.
If you add inline connectors on a powered antenna, put insulation (heat
shrink, electrical tape, etc.) over because a voltage will be present on
the metal connectors and it may find a ground path.
The piece inside the arch will probably be okay and there may be some
extra length in the run. Can you pull some up, add new inline
connectors outside the arch?
Gurther to the last, sometimes the connection inside the antenna (if you
can get in there without destroying it) is a simple bared wire solder
joint. That would eliminate a connector if you can attach to the new
antenna there.
If you don't know how to do it and can find someone like a HAM or maybe
a marine electronics shop to install coaxial fitting for you, there is
some chance that it will be done right.
Good luck!
Jack
