RJ45 jack pins
Discussion in 'Electronic Basics' started by Ant_Magma, Mar 9, 2006.
  1. Ant_Magma
    Ant_Magma Guest
    I just bought a couple of RJ45 jacks for my project.
    However when the component arrived, i realized that i don't know how to
    connect the pins
    http://www.farnell.com/datasheets/56092.pdf
    Which is pin 1 upto pin 8?
  2. Joel Kolstad
    Joel Kolstad Guest
    Looking into the RJ-45 socket (the upper left-hand drawing in your PDF file),
    the pins are 1-8 from left to right.
    Google will tell you this in far more color and detail if you'd like!
  3. Ant_Magma
    Ant_Magma Guest
    Thx Joel, i meant the pins under the jack. The ones i'm supposed to
    connect to the PCB.
  4. Hint: The pins don't cross.
