Bill said:
It's my understanding that "not linear" = "not ohmic". Sure, V=IR for
all I till the lamp burns out
(and even then), but if you were to plot V and I for an incandescent
lamp you would find that
there is not a straight line curve.
The fact that the resistance is not linear does
not mean it is not resistive. It doesn't magically
lose that property. Ohm's law applies, as you stated.
I don't have my "Standard Handbook
for Electrical Engineers" handy, it's at work, but I believe for an
incandescent lamp V is some non-integer power of I. R is decidedly not
constant.
You harp on R not being constant. Where do you see anyone
claiming it is?
Why...yes... yes I do. It is....misleading. So misleading as to be of
doubtful utility.
You call it misleading because you think it says
something that it doesn't. As to dubious utility -
Do you maintain that the computed 24 ohm resistance
is so far off that the bulb will either burn out or
be very dim?
It assumes that the power dissipated in the lamp is
directly.
proportional to the square of the voltage applied to its
terminals.
No it does not. It gives the resistance of the bulb at
its rating. The series resistor value is computed based
on that, such the the bulb, once hot, will "see" its
rated voltage. A 12 volt bulb rated at 3 watts in a
12 volt circuit will draw .25 amps. We want to increase
the voltage to 18, so we need to drop 6 volts. .25 amps
times 24 ohms = 6 volts. The bulb's resistance is not
linear. When it is cold, assume it to very low. The 24 ohm
resistor fed by 18 volts will try to draw to .75 amps.
The bulb will begin to heat, and its resistance will rise,
and the current will decrease. Pick a point where the
bulb's resistance equals 24 ohms, and compute again.
The current will be .375 amps, and 9 volts will be dropped
across both the resistor and the lamp. That's 3.375 watts
in the bulb - and that causes the resistance to continue to
climb. It will climb until the wattage dissipated equals
the wattage rating of the bulb, which occurs when the
circuit current is .25 amps, and the voltage across the
bulb is 12 volts.
This is not the case. A lamp bulb does not have a constant
resistance so the four-significant-figure calculations of power that
will be dissipated in the lamp are spurious.
The computations were based on the bulb running at
its ratings. Perhaps you would have no objection
if he had said "about 1.6 watts" instead of posting
the 4 significant figure? Maybe that's the whole source
of your complaint?
The name of the news group has "engineering" in it....we should try to
get the numbers right.
I note that you say "we" should get the numbers right,
yet provide no numbers yourself. Since you object to Phil's
numbers, propose your own.
