R
russ lavergne
I would think that this is available but I haven't seen it yet. I use a lot
of the AGE Fuses and I wish I had a little fuse that would fit in the
standard metal brackets that the AGE Fuses fit into but one that is
resetable. Like a little portable circuit breaker that you can pop into the
fuse that keeps blowing to help with troubleshooting. Has anyone seen this
and if so could you point me to it. The main thing is that it has to fit
into the bracket and can be removed easily. Also,
Another thing I would like is a 14 pin or 24 pin or what ever size IC chip
that you can program to be any chip you need. Lets say I need a 74LS174. I
get the blank 74 chip and pop it in my programmer and make it a 74LS174. Is
this already out there?
Russ
Russ
