N
N8N
Preventative Maintenance. or Project Management, depending on
context. Either one applies in my case
nate
This could turn into a whole new thread of major f*ckups that we learned
from....
Any good installation of an appliance like a dishwasher
should have a filter screen / rubber washer fitted to the hose fitting to
the tap that controls the water to the appliance
I just installed a couple dishwashers, one for us and one for a
friend, and one for a friend, no screen washers,,,,,,,,,
Hey that looks identical to the one I just yanked out of my place
When you remove the kick plate, you'll find adjustable screw feet
The solenoid valve will be right up front on the left side, mine is blue.
Hi James,
You gave me the courage to tackle this maybe-clogged dishwasher:
http://www.flickr.com/photos/donnaohl/sets/72157603947125744/
Here's a pic, taken just now, with the "kick plate" removed:
http://www.flickr.com/photos/donnaohl/2279869546/
Are you suggesting I can remove that blue "solonoid" on the left side with
the brass pipe in it and that might be what's probably clogged?
Donna
I might first think about using a good shop vac and start sucking at the feed
from the water heater or main entrance. open all taps, and of course close
main valve. I think the line would have to reseparated at the tank. The
dishwasher fill would have to be activated to open valve.
greg
Hi GregS,
Unfortunately, we do not have a "shop vac". My vacuum cleaner isn't likely
to do the job either ...
I will try tonight to remove the inlet water line if I can find where it
goes and to remove the solonoid to see if either have a screen.
If it's not that, then I'll look at the "float" and the "nozzle" wherever
they are, but first I'll try to see if it's the blue solonoid or the hidden
inlet screen if there is any.
Donna
Donna Ohl said:So far, on my side of the story, the water heater, full of tepid water,
fell over, and the drain valve popped off spewing water about. I won't
soon
forget that! The garage still stinks of smelly carpet!
The replacement of the water heater seems to have clogged all the faucets
(easy to clean), showerheads (even easier to clean), tub (still clogged),
and maybe even the dishwasher (work in progress).
I'm not sure *where* the sand came from but it's clearly in all the
faucets
so I guess we kicked it loose somehow in the water heater removal and
replacement process.
Anyway, now it's time to "remove" the dishwasher, if I can.
Does it look like it can be removed from these pictures taken today?
Counter Top:
http://www.flickr.com/photos/donnaohl/2279233722/in/set-72157603947125744/
Latch:
http://www.flickr.com/photos/donnaohl/2279869536/in/set-72157603947125744/
Bottom Right:
http://www.flickr.com/photos/donnaohl/2279869542/in/set-72157603947125744/
Bottom Left:
http://www.flickr.com/photos/donnaohl/2279869546/in/set-72157603947125744/
Do you think this dishwasher can be removed without breaking the counter
tile?
Donna
fell over, and the drain valve popped off spewing water about. I won't soon
I'm not sure *where* the sand came from but it's clearly in all the faucets
Counter Top:
Latch:
Bottom Right:
Bottom Left:
tile?
Donna
I always open an outside faucet wide open for about five minutes any
time the water is turned off to blow as much crap out of the lines
before using anything inside the house.
Hi Michael,
This is a GREAT idea! (if it works).
What I don't get is WHY there was all that sandy stuff after I replaced my
wagter heater. If anything, there should be LESS sediment in the lines, not
more (way more).
Where did all that sandy sediment that clogged every single faucet in our
tiny house come from?
Is this common that sediment blocks everything in one quick pass after
replacing a water heater?
If so, why did NONE of the tutorials I read mention that simple hint you
just gave us?
Donna
ahh when you turn off the water, drain the lines, and turn the water
back on. did you note the shuddering the first time you used water?
thats normal but you have galvanized lines full of crud which broke
loose and clogged stuff.
PEX and copper have smooth insides which dont collect crud.
sorry donna you need all your water lines replaced.
incidently water companies have the same trouble, and this is whu they
flush fire hydrants a couple times a year. confirms the hydrant works
and moves along dirt in lines.
thats why flushing sometimes causes brown or cruddy water- Hide quoted text -
- Show quoted text -
Hi Hallerb,
Ah. Yes. When the water was turned back on, there was a lot of sputtering
and shuddering going on, mostly sputtering. I thought it had to do with
the
new burner.
http://www.flickr.com/photos/donnaohl/2276890136/
But, this shaking & flushing of the pipes must have shaken loose sandy
grainy "crud" as every galvanized pipe I replaced was almost clogged
completely with what you called "scale".
http://www.flickr.com/photos/donnaohl/2273250265/
The water *was* brownish for a long while (you can see that in this photo
even after cleaning out the showerheads, so the crud was *still* coming
through the lines even ten minutes after initially turning the water back
on!
http://www.flickr.com/photos/donnaohl/2279233720/
I guess all that brownish was sandy grainy stuff that caught in the
filters
of *all* my faucets, showerheads, and dishwashers!
Nobody warned me about that so I'm *adding* it to the how to that I wrote
up!
I've only ever seen a couple houses that had galvanized pipes, and in one
case they were all being replaced. The sediment problem is something mostly
specific to galvanized, so it's not on the radar for most people.
Huh? Look most anywhere in the 'rust belt' or in areas where the housing
stock is largely greater than 80 years old ;-) Too bad that 'tutorials'
aren't directed at those situations to which they are most needed.
