D
dressden
Gurus, thanks in advance.
This TV has a strange symptom.
When powered on, the relay clicks and the HV comes on with no vertical
deflection or a very little vertical deflection bowed towards the
bottom.
However, after 5-7 minutes after the set warms up, the vertical
deflection comes on and the tv works properly for a long time.
I understand that the vertical defection is switched off until the
deguassing is complete on this model. However I cannot figure out
where to look for the fault, - Vertical or Degaussing or Power supply.
Has anyone seen this problem and could anyone point me to the section
to check.
bottom.
to check.
