Radionics 5700
N
No Name
Can this panel be programmed to auto arm/disarm? If so, can the user
enable/disable it and program the time of day to do it?
TIA
X
X. Boschman
TIA
It can be programmed to buzz when it should be armed (a time that can be
temporarily changed from the keypad) but it does not auto arm. This feature
was used by Honeywell to report a fail to arm message to the Central
Station.
By the way, although the system board says Radionics on it, this is a
Honeywell product made for Honeywell. It is an OEM version of the Radionics
D7112, which did NOT have this feature.
Your panel can (officially) only be programmed by someone from Honeywell.
Radionics sent the required software to Honeywell, who distributed it to its
centers.
Sorry I am so late in answering your question, but I didn't bring home any
Honeywell docs when I left the company, but I just found the Owner's manual
today and it refreshed my memory enough for me to give you a confident
answer.
X.
X.
C
Crash Gordon
ah the 7112...now there was a panel that almost put me outta business...radx
too.
M
Mark Leuck
too.
What was wrong with it?
C
Crash Gordon
Power supply/charging circuit problem that only showed up intermittantly and
way after you've sold it and installed it and chased *many* ghost problems.
At first radx skirted the issue...then came to ack it. Thankfully I had only
installed about 20-30 of them and I was a big enough dealer that they made
it right for me. Ended up pulling them all and replacing with 7212's. But,
it was still very costly for me even with free replacment panels - as I ate
the install time and had to deal with the clients. IMO it hurt Radx too .
If you come across any that are acting goofy you'll know it...I just pull
them and install something new.
X
X. Boschman
It was a nightmare for technical support as well. ANY panel by any RADX
dealer would be warranty replaced for about five years after the problem was
diagnosed. Didn't make it easier for the dealers, though.
Did you know the D9112 was just going to be a bigger version of the D7112
until the product manager decided to go on the road, get dealer feedback,
and implement the suggestions? It slowed the release of the D9112B, but
resulted in a much better designed product that is still successful.
The original D9112 prototype had a seven digit point code instead of the
much more flexible point indexes (which had their own potential for
confusion, but were IMO a much better approach than pseudo-binary
optioning).
X.
C
Crash Gordon
Yah it was bad.
Almost as bad as the 636 keypad issue. I'm the guy (unfortunately) that
discovered that problem and worked for months with techs on troubleshooting
and finding the cause. Thats going waaayyy back.
X
X. Boschman
Crash Gordon said:
Yah it was bad.
Not THAT way back! I remember it well. :-(
More extended warranty exchanges, but not for as long as the D7112 charging
circuit issue. Boy, you are bringing back some wonderful (?) memories!
X.
C
Crash Gordon
I thought you'd enjoy the memories :))))
And then...when programming sheets became as thick as War & Peace... I
started selling other products...went from being 99% Radx to now only repair
or replace 'em.
X
X. Boschman
Um.........
or replace 'em.
I never found the programming bloat all that daunting, myself. I created
the flexibility that our customers were demanding while structuring the
programs in a familiar and recognizable set of modules. What I didn't care
for was the D6412 programming interface (Nibbles 'n' bits. Nibbles 'n'
bits. I gotta get me some nibbles 'n' bits). And no DF200 programming! I
think the clear break wiht the past (among other things) had more of an
effect than the increase in programming options. But everyone is different
and has differing requirements and tastes.
X.
N
Nomen Nescio
Talking about dumbass ideas from Radionics:
Soldered-in lithium batteries.
When the panel loses both AC and battery power, if the lithium battery is
dead you cannot get into the panel with a programmer. You have to send it
back to the factory for a new battery. So if you have a spare 7212 on the
shelf that's been sitting for a few years, odds are you won't be able to
program it when you need it. Same thing if you have an older panel out in
the field that loses both AC and battery: the programming is gone, and you
can't reprogram that panel.
X. Boschman, if you know a workaround for this, you'd be performing a
public service by telling us about it.
C
Crash Gordon
Power up the spare one in the shop...solder in a new battery while it's
powered up...and pray?
I'm such an idiot..once I changed a lithium on an older DMP. I thought I was
supposed to power it down first...duh...pretty dumb.
Jackcsg
Well at least you learned, and hopefully you only did it once....
C
Crash Gordon
It was one of those "inverted data-bit days"...you know when the little
voice in your head is telling you the right way to do something, but your
hands just go ahead and power the panel down and remove the battery anyway?
F
Frank Olson
anyway?
I used to have days like that... Now I'm happy just standing behind my
counter. ;-))
"Would you like an apple pie with that?"
C
Crash Gordon
So it's troo then...you work at Alarm Shack?
I'll have a spicy fried Simon 3 with a side of slaw.
X
X. Boschman
This is about the only solution for the older panels. Since the 9412
series, the lithium battery is "spring" held and easily replaced. But the
panel MUST be powered us in this scenario as well or else, poof, panel
repair.
X.
X
X. Boschman
Sounds like you had reversed polarity to me.
X.
Jackcsg
X.
I once, as an experiment of course, left the battery hooked up backwards on
a DMP XR-200 for a couple of weeks...no damage to the panel though....it was
cool.
N
Nomen Nescio
repair.
Since a dead lithium battery results in a datalock violation, the
programmer cannot load a default program into the panel once the panel
memory is cleared. I've always figured the datalock protection is part of
the programmer's firmware, rather than the panel's. Meaning, the
programmer won't cooperate if the datalock code it reads from the panel is
different from those stored in the programmer.
How difficult would it be to create a black box that plugs into a panel,
ignores the datalock code, and loads a default program into the panel, even
if the panel's memory is blank? Might be an interesting product for an
ex-Bosch-man to offer.
