John said:
Sure; just use it to replace Rf. Use a multiplying DAC for the same
effect but less work. Beware the added capacitance, though... this can
make an opamp oscillate.
John
Yes, I'm thinking about multiplying DACs as well. I'll probably try that
first.
I thought it was pretty obvious how to use an R-2R network in the
feedback loop: instead of putting logical 1's on the bit inputs, just
put the output of the op-amp. But a lot of references suggest that if
you don't put a 1 on an input, it must be tied to ground. So in this
case, where do I tie the "low" inputs? To ground? That would seem to
imply a digitally programmable woltage divider on the output, I don't
recall incorporating voltage dividers into feedback loops though I have
a vague feeling it will work. I used to be very handy with op amps,
guess I just have to put my thinking cap on.
I was just hoping there might be some clever configuration I was missing.
-Jeff
