Question: DC analysis of a transistor amplifier?
samy555
May 11, 2010
63
May 11, 2010
63
I could not complete the analysis of this circuit.
This is what I managed to do:
IB1 = (VCC - VBE1)/R3 = (3 - 0.7)/100K = 23uA
If β = 100, then IC1 = 2.3mA
VCE1 = VCC – IC1 * R1 = 3 – (2.3m* 2.2K) = - 2.06 V (Error)
The Voltage between points A & B (VAB) = 0.7 volt
So, IC1 = VAB/ R1 = 0.7/2.2K = 0.318 mA
Then, VCE1 = 3-0.7 =2.3 V
I stoppedhere. I wish I couldcalculate IC2 and VCE2 to complete the picture.
Thank you.
LvW
Apr 12, 2014
604
Apr 12, 2014
604
Yes - it is an interesting circuit - sometimes called "current starving" circuit.
The value of Ic1 sounds reasonable. However, it does NOT go entirely through R1. In contrary, the majority of Ic1 is identical to the base current Ib2 of the pnp (Q2).
Hence, continue the calculation with I(R1)=0.7/R1 and Ic1=I(R1)+Ib2.
Ratch
Mar 10, 2013
1,099
Mar 10, 2013
1,099
Yes, base current is an indicator and somewhat proportional to the collector current.
No, that is not correct. IC1 is the sum of the current existing in R1 AND the base current of IC2.
Yes, that is correct.
Wrong. IC1 is the value stated above.
Yes, the emitter-base diode of IC2 holds the voltage of R1 at around 0.7 volts.
IC1 is 2.3 mA. 0.318 mA comes from R1, so 2.3 mA minus -0.318 mA = 1.95 mA comes from the base current of IC2. Multiply this current by 100 and you get IC2=198.2 mA. You can take it from there. You should notice that IC2 saturates, and cannot supply198.2 mA. It seems to me that a simple diode across R1 would not change current present in IC1.
Ratch
