Z
[email protected]
There must be a very simple stupid answer to this and I could really
use some help knowing what it is :/
Consider a mesh-current analysis problem where the circuit contains a
current source. Every text and website I can find on the topic gives a
nice simple example where the current source is along the junction
between two meshes, and I understand how to set up a phantom voltage
across this source, which is canceled out by adding the two equations
for the meshes that adjoin.
However I do not for the life of me understand how to set up the
equations for such a circuit where the current source is on the edge
of the circuit. It's driving me crazy!
I've put an example of the sort of problem I mean at <http://
www.larwe.com/ebay/mesh.jpg>. I think (THINK) I can correctly deal
with the 10A source on the top edge, but the dependent source on the
bottom right corner has me utterly baffled. I assume KCL is used to
determine that the current through the 1 ohm resistor is (2Vphi/5) +
10 but what's the current in the 5 ohm?
Or in general what is the plan of attack when faced with a current
source at the periphery of a problem where mesh-current analysis has
been mandated?
(This detestable text has no solutions for the "drill exercises", just
answers. Useless).
Thanks for any help you can provide...
been mandated?
answers. Useless).
