C
Charlie E.
Hi All,
Ok, after never before having an opportunity, I designed my new boards
with SM caps. Didn't think there would be any problems soldering
them, but have run into a real problem.
Every single dang one of them shorts out when I solder them down. They
are Murata 0805 caps, and the only thing I can think of, is that there
is this little metal 'clip' on each side that must be shorting the
pads together. if if remove one of the caps, it is definitely not
shorting internally.
I just used the standard 0805 footprints in the Orcad Layout library,
and haven't had any problems with the resistors, just these darned
caps! Has anyone else seen problems like this? Or am I just making
some simple newby mistake?
Charlie
Charlie
