K
Kyle Winters
Hello all,
I am having a problem moving my circuit from a power supply to a battery.
The circuit (I can provide more details if necessary) is basically some
74LSxx IC's which are turned on/off via signal from a PC. The outputs
control the state of relays which allow motors to be driven via 12V.
To date, I have been doing all my testing using a PC power supply - 12VDC
for the motors and 6VDC for the circuit - and this worked perfectly. I
(wrongly) assumed it would be a simple matter to change from the power
supply to a battery for the power source.
I sourced two SLA batteries (1 x 12VDC, 1 x 6VDC) to replace the power
supply but the circuit no longer works. The 12V for the motors is working
fine. When I run the circuit from the battery, the relays never switch.
The circuit is drawing 150mA @ 6V.
I can switch from the battery back to the power supply and everything works
OK, so I know the devices in the circuit are still working fine. But this
is about the extent of my troubleshooting knowledge. I get the feeling I am
missing something basic. I thought maybe the 6.4VDC being output by the 6V
SLA battery was too high, so I put a 5V voltage regulator in which dropped
it to 4.4VDC (I still haven't figured out why so low - but that's another
story!) and it still doesn't work. If I leave the voltage regulator in, I
can still run fine from the power supply.
I thought it may be drawing too much current for the battery, but that
doesn't really make sense to me - it's only 150mA. The details of the
battery are (I am copying this straight off the battery case):
6V 2.5AH
Cycle Use: 7.25-7.45V
Standby Use: 6.8-6.9V
Initial Current: Less than 1.2A
Before I start blundering around blindly with the "insufficient current"
theory, is there anyone who could have a stab at this for me and tell me why
I can't just switch from power supply to battery?
Many thanks,
Kyle.
6V 2.5AH
Many thanks,
Kyle.
