M
mm
I can't do subtle repairs, but I"m ok replacing power supply filter
capacitors when I hear the typical 120 cps hum in the speakers.
And I had always thought that the filter capacitors fail by opening,
rather than shorting, because I figured there would be sparking and
smoking if the cap was shorting.
Is this so?
In this case, I'm trying to fix up a high quality Panasonic table
radio from the 70's I think. It used to give perfect sound, but the
hum has appeared about 3 months ago.
There are 3 16-volt 2200mF capacitors in the filter, and two of them
are connected at the posive end to the +25 volt, and one is connected
at the negative end to the -25 volt location. The other ends are
connected to the chassis. Normally I cut out the old caps and replace
them, but to learn something, I used some wires with alligator clips
to connect a new 2200mf cap in parallel with the old one, or a new
4700mf cap in parallel with the old two in the other case. This did
nothing to make the hum go away. Should this have worked if one or
more of those 3 caps were bad?
!!I just found another fairly large cap, 1000mF, on the circuit board.
I'll have to take the whole thing apart to get to it. Given the
previous paragraph, is there any point to first changing any of the
first 3 caps, which are very easy to get to?
If you are inclined to email me
for some reason, remove NOPSAM
Is this so?
