I suppose it would be best to simply purchase a pack already containing the cell count I want. I just have all these 18650 3.7v lithium ion batteries and would like to do something with them before they go bad if they do.
Thanks.
You could always buy additional 18650 cells
You can do what you want with them, as long as you observe the limitations of your individual cells.
Mixing and matching cells means that in a series connected string, the current must not exceed the capability of any individual cell in the pack... This also means that the cell with the lowest capacity will dictate the run-time of the pack.
Of course, parallel is a different monster. Voltages must be the same of all the cells, although capacity can vary.
As the voltage drops in the less capable cells, the more capable cells will be drawn from instead. The over-all mAh capacity can still loosely be summed, but the 'peak' or 'constant' current draw of the pack cannot be.
The dangers with both packs is excessive current during discharge or recharge state, as well as under-voltage or over-voltage conditions. Some cells have built-in protection from the above conditions, some don't, and many have a very 'loose' enforcement of restricting damage conditions... (ie... short protection that trips at 10A for a cell rated at maybe 2A peak draw
It's just so much easier to match the cells is all.
Lithium, when abused will begin to heat up, and the cell will begin to expand from gasses being created in the cell... Eventually, the cell wall will rupture and vent the gas which usually ends up in a small fire from the exposed innards.
Always be safe. If you venture into "you *can*, but probably shouldn't territory", some not so fun things can happen.
