P
Peter Constantinidis
I was experimenting with a couple incandescent lamps, when I noticed a GE
60 watt bulb was the same brightness and color seemingly, as the 60 watt
Philips halogena one i was experimenting with which was a lot more
expensive. I also had Philips regular incandescent bulbs and a few others
but they didn't have the same 'pop'.
I held both bulbs up to the light (heh heh) and I saw that in the Philips
one, the filament is horizontal. But in GE bulbs, the filament is vertical,
and longer than the horizontal Philips one.
So I think based on that bit of empirical evidence, that a vertical
filament provides more surface area to throw off light with and may also be
burning hotter due to the whiter color, the GE bulbs are better as when new
they look pretty much the same as Halogena bulbs for a lot less $.
Regards,
P.
Regards,
P.
