PIC and 10-Bit ADC
Discussion in 'Electronic Basics' started by [email protected], Feb 11, 2006.
  1. Guest
    Okay something again I need to wrap my head around.
    My PIC datasheet says that it reads the 10-bits from a 16-bit analog
    register based on the analog input.
    ADRESH takes the first 10-bits, and ADRESL takes the last 10-bits.
    If my input voltage is say 2.564 volts, what would be the ADRESH and
    ADRESL, barring any binary conversion.
    I know that I have to divide 5/256 to get 20ma increments that are
    detectable.
    But am I going to get the actual 2.564 fully read in to either of these
    registers, or am I going to lose some info if I take the wrong 10-bits?
  2. Please tell me what document told you this. A PIC model number would
    also be helpful to us. Since you didn't specify one, I will pick the
    16F88.
    Hardly. ADRESH and ADRESL are only 8 bits each in size. The 10 bit
    result can be left justified or right justified depending upon another
    SFR bit setting. The ADFM bit in the ADCON1 register determines whether
    the result will be left or right justified accross the two ADRESx
    registers.
    We would need to know what you are using for Vref to tell you that.
    Assuming that you are using a 5V Vcc as your Vref then each increment
    would correspond to (5/1024) or about 4.88mV.
    10-bits?
    Again, the registers are only 8 bits in size. That's why there are two
    of them. To achieve 10 bit precision you will need the data from each
    register. If you only want an 8 bit result (giving 4.88mV * 4 or about
    19.53mV per increment) then specify left justification by clearing the
    ADFM bit in ADCON1, take the value of ADRESH and ignore what's in
    ADRESL.
  3. Actually, I think you can choose left justified (upper 8 bits in
    ADRESH, lower 2 bits in high end of ADRESL, others zeroed) or right
    justified (high two bits in low end of ADRESH, others zeroed, lower 8
    bits in ADRESL)
    2.564 out of 5 with a 10 bit resolution is (2.564/5)*1023 = 525
    (rounded to the nearest integer) decimal or 1000001101 binary.
    If set up for left justified, ADRESH would hold the left 8 bits of
    that, or 10000011 and ADRESL would hold the right two bits in its left
    end with the rest filled with zeros, or 01000000.
    If set up for right justified, ADRESH would hold the left 2 bits of
    that value in its right end, with the left bits filled with zeros, or
    00000010 and ADRESL would hold the right 10 bits or 00001101.
    If you just want the voltage measured using the most significant 8
    bits and intend to waste the lower two bits, use left justification
    and take ADRESH as the result. If you intend to do treat the result
    as a 10 bit binary value that fits in a 16 bit space, (for instance,
    if you intend to do some 16 bit math on it to perform digital
    filtering) you use right justification and both registers.
    If you use left justification and the ADRESH value as an 8 bit
    conversion (0 to 255 range), each count in ADRESH represents 5 volts
    divided by 255 or .01961 volts. If you use right justification and
    use both resistors to measure the voltage as a 16 bit number (with
    only 10 of those bits ever used, each count represents a voltage of
    5/1023 or .00489 volts. But your program will have to make magnitude
    decisions based on two byte programming, so each value comparison will
    be a little more complicated.
  4. AIUI the divisor to use is 256.
    1024 :)
  5. There are 256 possible voltages to be measured, but one of them is
    zero, so the range is divided by 2^8-1.
    One less, for the same reason. 1024 end points, but only 1023 spaces
    between them.
  6. Assuming a Vref of 4.096V and an "ideal" 10 bit ADC to make things
    simple, a conversion result of 0 would actually encompass the range of
    0V-.00399R Volts; the second range for a reading of 1 is .004V to
    ..00799R Volts. Consequently the final range would be for (1023*.004)
    4.092V thru 4.096V. Is that not correct?
  7. The way I see it, each level is ideally converted with an accuracy of
    +,- 1/2 LSB, except for the first and last level. 0 is converted to
    an accuracy of -0, +1/2 LSB and the highest level is converted to an
    accuracy of -1/2LSB to +0.
  8. I can't find any mention of excepting the first and last levels in the
    datasheet nor in the mid-range reference manual. I can't help but
    wonder why precision voltage references obviously assume 2(n) steps and
    not 2(n)-1. FWIW, my John Peatman book seems to agree with me. Perhaps
    an ADC expert could shed some light on this?
  9. Bob Monsen
    Bob Monsen Guest
    Why is the last level (255) only representing a range up to Vref - 1/2
    LSB? Given your analysis, it only gets within 1/2 LSB of Vref. To me, that
    means you have an extra 1/2 LSB left over to explain... ;)
    However, if you assume that the output is based on the floor of the
    range (which I believe is the case) then everything works out properly:
    0*Vref/256 to 1*Vref/256 -> 0,
    1*Vref/256 to 2*Vref/256 -> 1,
    2*Vref/256 to 3*Vref/256 -> 2,
    255*Vref/256 to 256*Vref/256 -> 255.
    Unless I'm miscounting, that means you have 256 voltage ranges, which map
    neatly to the 256 values that your 8 bit ADC output can take on.
    OTOH, the difference between 1/255 and 1/256 is so small that this
    will make absolutely no difference for most situations, except that you
    won't be able to use shifts to do the math.
    Regards,
    Bob Monsen
    We should take care not to make the intellect our god; it has, of
    course, powerful muscles, but no personality.
    Albert Einstein
  10. I think I have made a mistake about the voltage per step being 1/2^n-1
    times the full scale voltage, because that conflicts with the first
    and last levels being at 1/2 LSB value. But I think it is true that
    the first and last step are 1/2 LSB, while all the others are 1 LSB
    wide. Here is an excerpt from a National data sheet for an 8 bit
    successive approximation A/D converter:
    http://cache.national.com/ds/DC/ADC081S101.pdf
    (begin excerpt)
    Code transitions occur midway between successive integer
    LSB values. The LSB width for the ADC081S101 is VA/256.
    The ideal transfer characteristic is shown in Figure 5. The
    transition from an output code of 0000 0000 to a code of
    0000 0001 is at 1/2 LSB, or a voltage of VA/512. Other code
    transitions occur at steps of one LSB.
    (end excerpt)
    Unfortunately, the voltage versus count diagram immediately following
    does not reflect this paragraph.
    However, I have seen others that do.
    For instance, all the voltage versus count graphs in this Maxim
    application note show the first step as 1/2 LSB and all the rest as 1 LSB.
    http://www.maxim-ic.com/appnotes.cfm/appnote_number/748
  11. Here is another reference that mentions both the first and last step
    being only 1/2 LSB and the voltage per step (1 LSB) being (1/2^n -1)*Vref:
    http://focus.ti.com/lit/an/slaa013/slaa013.pdf
    (begin excerpt)
    The width of one step is defined as 1 LSB (one least significant bit)
    and this is often used as the reference unit for other
    quantities in the specification. It is also a measure of the
    resolution of the converter since it defines the number of
    divisions or units of the full analog range. Hence, 1/2 LSB represents
    an analog quantity equal to one half of the analog
    resolution.
    The resolution of an ADC is usually expressed as the number of bits in
    its digital output code. For example, an ADC
    with an n-bit resolution has 2n possible digital codes which define 2n
    step levels. However, since the first (zero) step
    and the last step are only one half of a full width, the full-scale
    range (FSR) is divided into 2n – 1 step widths.
    Hence
    1 LSB = FSR/(2^n - 1) for an n bit converter.
    (end excerpt)
  12. Bob Monsen
    Bob Monsen Guest
    You appear to be right about the first transition starting at 1/2 LSB
    after 0. This makes the jagged line on the graph of voltage vs values have
    a smaller difference between the 'theoretical' line, thus making the
    digitization error smaller.
    However, they are wrong about that divisor, at least for some ADC chips.
    It is pretty confusing, I'll agree, but if you just make yourself a graph
    of input voltage vs output codes, you see that the last value represents
    3/2 LSB. (This is also pointed out in an Analog Devices datasheet for the
    AD9226, page 7 and 19.)
    The voltage is exactly represented at the midpoint of each step, so there
    is a possible error for each bit of up to +- 1/2 LSB. Now, imagine a 2 bit
    converter (so to speak...) that uses a FS Vref of 1V. It'll have
    output transitions at 1/8, 3/8, and 5/8V. That means that for an output
    value of 1, the input voltage was 1/4 +- 1/8. For an output value of 0,
    the input voltage was 0 +- 1/8. etc. So, the input voltage is within 1/2
    LSB (1/8V) of output/4.
    The AD9226 actually considers input voltages that are greater than -1/2LSB
    to be valid inputs, and considers input voltages above FS - 1/2LSB to be
    *invalid*. The out of range output pins are defined this way.
    However, it is possible that the scale is stretched on other converters.
    If the scale is stretched, then for those converters, the LSB may actually
    be as you say. For our 2-bit converter, that would make transitions at
    1/6, 3/6, and 5/6. This would result in a maximum error of 166mV as
    opposed to 125mV with the other encoding scheme, and thus a bigger
    encoding error.
    Regards,
    Bob Monsen
    Albert Einstein
  13. That's roughtly the way I see it. The only thing I would change is that
    your numbers are a little bit ambiguous in that you allow one voltage to
    return two different values. That's why I went with the 999R thingy.
    It seems to me that precision (.1%) voltage references indicate that
    2(n) is the appropriate divisor.
    True, but we're being pedantic here. ;-) Besides, I really want to
    know which is correct. With Google it's a split decision. Microchip
    documentation seems to agree with 2(n), but others agree with John.
    Now there's somebody worth quoting. (;-)
  14. This all sounds simple/reasonable enough.
    I'm with you so far. ;-)
    I'm kinda dumb, so I don't really get how they arrive at that
    completely. :-? I can see that it might be hard to acheive + or -
    resolution at the extreme ends of the scale since you can't really be
    less than 0 or greater than Vref so that would seem to remove half of
    its range, making the first and last steps half-width.
    The Peatman books show a stair-case with input voltage on the horizontal
    scale and the ADRES value vertically. The first step is flat (ADRES =
    0) for a full step width. The last step peaks early in the way that I
    described (returning 0x3FF for a voltage less than Vref. Next time I'm
    tinkering with the PIC ADC, I'll do some measurements to see where the
    first (0x00 -> 0x01) and last (0x3FE -> 0x3FF) transitions occur. It
    should prove kinda interesting to see if the first transition occurs at
    2mV (4.096 reference).
  15. Bob Monsen
    Bob Monsen Guest
    I think it depends on the converter. I bet some do it one way, and others
    do it the other way. It is an arbitrary choice. One way gives you more
    steps, and thus less quantization error, while the other way gives you a
    larger usable range.
    Regards,
    Bob Monsen
    Imagination is more important than knowledge...
    Albert Einstein
  16. Yes, we should pick a particular A/D and nail that one down, first.
    Then we will be in a position to look for exceptions.
  17. Bob Monsen
    Bob Monsen Guest
    Look at figure 14, page 19 of this one:
    http://www.analog.com/en/prod/0,,AD9226,00.html
    Regards,
    Bob Monsen
    You cannot simultaneously prevent and prepare for war.
    Albert Einstein, (attributed)
  18. I looked, but it doesn't make sense to me. The -FS and +FS ends of
    the scale are not symmetrical, with the lowest output transition
    taking place at (-FS) +1/2LSB, but the highest transition taking place
    at (+FS) -1 1/2 LSB, which can't be correct. Can it? Is there any
    A/D data sheet that gets everything correct? No wonder there is
    disagreement on how these things work.
  19. Pooh Bear
    Pooh Bear Guest
    It's been jolly interesting following you guys discussing this.
    I rather think you left the OP at the starting line though ! ;-)
    Graham
  20. You'll have that, sometimes. I'm here on a generous impulse, but when
    something comes along that serves my education, I have no problem
    taking a detour. We spent quite a bit of effort explaining the left
    and right justification modes and ranges of the O.P.'s A/D, before we
    left him to explore this detail. And just because we are doing this,
    you are certainly free to continue with the hand holding.
