Hi, Can anyone help me designing peak detector for signal ranging from 0 - 5 v. Regards Hemant
H hemant Jan 1, 1970 0 Oct 26, 2004 #1 Hi, Can anyone help me designing peak detector for signal ranging from 0 - 5 v. Regards Hemant
C CFoley1064 Jan 1, 1970 0 Oct 26, 2004 #2 Subject: Peak detector design resources From: [email protected] (hemant) Date: 10/25/2004 11:12 PM Central Daylight Time Message-id: <[email protected]> Hi, Can anyone help me designing peak detector for signal ranging from 0 - 5 v. Regards Hemant Click to expand... Hello. Have you looked at National Semiconductor AN-31, Op Amp Circuit Collection, p.18? http://www.national.com/an/AN/AN-31.pdf About the only negative is that you'll need one -- you have to use bipolar supplies. Chris
P Paul Taylor Jan 1, 1970 0 Oct 29, 2004 #3 hemant said: Hi, Can anyone help me designing peak detector for signal ranging from 0 - 5 v. Regards Hemant Click to expand... The LMV331 datasheet example should work well? http://www.national.com/ds.cgi/LM/LMV331.pdf Paul
