Panasonic DMR-E55 Help with component values
T
TJB
I Have a DMR-E55 with the perpetual restart-self-check problem. I have
narrowed it down to a faulty IC001 - STRG6353. I also have a couple of
other parts which are faulty R003, a 1W resistor, but I can't read the
value, measures 0 ohms, as does diode D005 a T3D46. The 4 and the 6 have a
small bar above them??
Hopefully I haven't missed any other faulty parts.
Anyone help me on the value of R003, a nd what the heck kind of diode is a
T3D46?? I can't seem to find any data on this at all!
Thanks for any help.
TJB
joe
TJB
R003 is a 0.47 Ohm and D005 is an ST3D200
HTH
T
TJB
HTH
Thanks Joe,
With R003 being a 0.47 Ohm resistor I better get out the more
accurate meter and measure it properly, although hard to read it may
actually still be okay. D005 measures close to zero either polarity, so
I will replace it along with IC001.
Thanks again for the help
TJB
T
TJB
Thanks Joe,
so I will replace it along with IC001.
TJB
Oops what am I saying, D005 measures open circuit either polarity.
I can't find any details about D005 in my data books or on the web. Joe
do you have any info/data on this diode???
TJB
T
TJB
Joe do you have any info/data on this diode???
TJB
Found some data, it's a zener and normal diode back-to-back so normal
multimeter testing won't work. IC001 may be the only replacement
required.
Cheers
TJB
joe
required.
Cheers
TJB
These diodes are usually OK. Just replace the STRG6353 and check the
electrolytics and all should be well. A dab of thermal paste on the IC
heatsink also helps.
T
TJB
Thanks Joe, I have ordered IC001, hopefully it will work.
Cheers
TJB
