A
Alex Rast
I have a part in a library, under OrCAD capture 9.0, that we got from a
third party. However, I suspect it's corrupted. It's a heterogeneous part,
but irritatingly, there's one too many parts in the package. One of the
"parts" is blank. So I want to delete it. However, when I edit the part in
the library, go into Package View, and try to edit, under package
properties, the "Parts per package" setting, I get a dialog "Deletion of
heterogeneous parts can ONLY be done from the package view". Given that
this is the view I'm in, there's some problem. In addition, if, in Package
View, I do an "Edit...Properties", I get a "The Package Spreadsheet cannot
be displayed because no pins have been placed" dialog. There are obviously
placed pins because for each of the non-blank parts, there are pins
displayed and if you go into Part View, you can edit the properties of the
pins. I also tried adding a pin, but even with this added pin, when I went
back to Package view and did the Edit...Properties", I got the same
message.
So all this behaviour leads me to believe the part is corrupted somehow.
I'd like to be able to fix it without starting over. Is there any way to do
this? I can get creative, such as using a hex editor, copying to a
different file, importing into another program and reexporting, etc. if
that's what's required.
NB: There's no implied or explicit restriction of rights between us and
this third party. In other words, we got the part freely, with the
understanding that we could modify it at our leisure or redistribute it as
necessary.
message.
necessary.
