W
[email protected]
I have an old 8 gernamium transistor, protable AM radio that is noisy
on weak stations when cold. It works reasonably well when set it in the
sunshine and warms up. The problem seems to be the RF section since the
noise goes away when the volume is turned down. I'm suspecting the
germanium transistors may be the problem and wondering which one might
be replaced with a silicon variety to cure the temperature problems?
I'm not sure what all 8 transistors do. Two are in the output stage,
and another is used as a audio driver that drives the audio input
transformer.There are four RF coils, the usual oscillator (red) and
mixer (yellow) and white (1st IF) and (black (second IF). But that only
requires 6 transistors, and there are eight total. The detector is a
diode, so they didn't use a transistor for that. I haven't figured out
what the other 2 transistors do.
I'm thinking of replacing the oscillator transistor with a high gain
silicon variety to try and eliminate the temperature problems?
Any other ideas?
-Bill
Any other ideas?
-Bill
