harrogate2 said:
What a load of crap!
The danger from electricity is NOTHING to do with supply frequency -
it is all about current. A current of 30mA - that is 0.03A - passing
through your body across your heart will usually be fatal. 10mA may
cause problems, but in a healthy person will usually not be fatal.
120V (to earth) as used in the US is specifically chosen since it is
rarely high enough to cause 30mA current flow through the body: by the
same token here in the UK and across most of Europe, 110V (actually
55-0-55) is used professionally for power tools etc.
The number of people who believe that normal household current is not
lethal or that powerlines are insulated and do not pose a hazard is
alarming. Electrocutions may result from contact with an object as seemingly
innocuous as a broken light bulb or as lethal as an overhead powerline, and
have affected workers since the first electrical fatality was recorded in
France in 1879 when a stage carpenter was killed by an alternating current
of 250 volts. 2
However our normal mains is 220V in Europe, 240V in the UK (that is to
earth) and can be fatal. I understand that in the US 240V is available
across both supply lines but it is actually 120-0-120 and thus much
less dangerous.
My my, you seem to be very educated in this subject if what I said was a
load of (incorrect information.) Can you explain what happens to the heart
to make it stop? Why doesnt a defibrillator, which probably jolts more than
30mA, cause a person to die?
It would be proper for me to quote sources, rather than assume;
When current greater than the 16 mA "let go current" passes through the
forearm, it stimulates involuntary contraction of both flexor and extensor
muscles. When the stronger flexors dominate, victims may be unable to
release the energized object they have grasped as long as the current flows.
If current exceeding 20 mA continues to pass through the chest for an
extended time, death could occur from respiratory paralysis. Currents of 100
mA or more, up to 2 Amps, may cause ventricular fibrillation, probably the
most common cause of death from electric shock. 11 Ventricular
fibrillation is the uneven pumping of the heart due to the uncoordinated,
asynchronous contraction of the ventricular muscle fibers of the heart that
leads quickly to death from lack of oxygen to the brain. Ventricular
fibrillation is terminated by the use of a defibrillator, which provides a
pulse shock to the chest to restore the heart rhythm.
11. Dalziel CF, Lee WR [1968]. Re-evaluation of Lethal Electric Currents.
IEEE Trans. Ind. Gen. Appl. IGA-4:467-476.
http://www.cdc.gov/niosh/pdfs/98-131.pdf
