Julian Edgar
I am using an inverter to run a conventional PC in a car. The audio from the
PC is fed through RCA cables to a FM modulator that connects in-line with
the car radio aerial, allowing the PC's sound to be heard on a specific FM
frequency.
The problem is that there is a great deal of background noise which is
easily audible, especially when there is no music playing.
When the FM modulator is connected to (say) a portable CD player, there is
no noise. When the PC output is directly monitored with headphones, there is
no noise.
Using a suppression capacitor (normal car radio type) between the earth of
the RCA signal leads and the chassis removed a high pitched component of the
noise. However, there remains a noise which sounds very much like white
noise.
This noise level doesn't change with adjustment of the PC volume output.
However, it changes in level with adjustment of the FM modulator output
level or the radio volume control.
The noise doesn't change in level whether the car's engine is running or
not.
I have separated the RCA cables from other wiring - originally they were
bunched with other leads - however the noise as described is still present.
I have tried a variety of capacitors between the RCA earth and the chassis
and while I can get rid of the high pitched noise, I cannot reduce the other
components.
Any ideas?
frequency.
no noise.
noise.
not.
components.
Any ideas?
